Forums >> Revit Building >> Technical Support >> Same detail
Tue, Aug 28, 2018 at 1:53:01 PM | Same detail
1bchristian
Revit 2017 - Is it possible to place the same detail on two differnect sheets? - Thanks Byron
Tue, Aug 28, 2018 at 2:42:37 PM | Same detail
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Depends. Is it a hybrid detail? i.e. is the detail part of the 3D model with 2D content? If so, create the detail from the section or plan, add the 2D content and place it on sheet. Then on that sheet select that detail and duplicate it with detail. It will make a copy up the top of the project browser. Drag that onto the second sheet. Now the detail is currently the same but on separate sheets. You will need to change both details on both sheets if they change but they both exist from the same source. If the detail is a 2D detail in Revit, create it, duplicate it and past them on separate sheets. You cannot have one detail on two sheets. That would cause confusion and a documentation nightmare. It would not be recommended.
Wed, Aug 29, 2018 at 6:42:44 AM | Same detail
tim123
4 Stars: 19 Votes
You can duplicate as a dependant, and the dependant view will display the same detail as the parent view, even if it changes.  You will have to name them differently though (eg Section-1 and Section_1 and Section 1).
Creating an Enlarged Detail View of a Detail I have Drawn
Fri, Aug 31, 2012 at 7:05:29 AM
Detail components in multiple views.
Tue, Aug 18, 2009 at 2:46:35 PM
Nesting Detail Components
Mon, Sep 29, 2014 at 3:46:09 PM
link detail drawing from another drafting view in the same project
Wed, Oct 12, 2011 at 11:14:00 AM
Multiple Detail Numbers In View Title
Mon, Apr 11, 2011 at 12:24:54 PM
Page generation time: 0.1930
