Forums >> Revit Building >> Technical Support >> Can't cut a section
Thu, May 31, 2018 at 10:24:05 AM | Can't cut a section
1bchristian
I am in a plan and attempt tp cut a section. I get this message
"None of the created elements are visible in Floor Plan: FLOOR PLAN View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
what do I need to do I am in version 17 - Thanks Byron
Fri, Jun 1, 2018 at 1:03:43 AM | Can't cut a section
tim123
4 Stars: 19 Votes
It means that something is stopping the sections from being seen.  First check your VG settings to see if they are switched off.  If not, check the scale of the sections - they have a parameter to make them not show at certain scales.  Then check if there is a view filter that is hiding them.  Theses are the first things to check for.
Fri, Jun 1, 2018 at 2:08:04 PM | Can't cut a section
I don't understand... you title this as a section cut but you talk about floor plan.  Is this a section or is it a plan detail?
Fri, Jun 1, 2018 at 2:35:15 PM | Can't cut a section
1bchristian
I have the solution from the first response - Thank you
Tough one - Phased site topography and visibility in section
Thu, Jun 9, 2011 at 11:58:34 PM
Cut Pattern in Plan vs Section
Tue, Aug 25, 2009 at 8:47:59 AM
Sections cut on mulitple sheets
Fri, Jun 27, 2008 at 12:33:38 PM
When I cut a section or elevation in revit, it shows what's behind the cut plane
Fri, Dec 6, 2013 at 12:47:17 PM
Is it possible to not have the bold section cut lines
Thu, Apr 3, 2008 at 12:58:16 PM
Page generation time: 4.1207
