Forums >> Community >> The Studio >> how to create own objects
i was wondering how you can create your own objects in Revit.
By creating a family - look at family tutorials
where at? here on the website or in the program?
In the program - go to 'Help' pull down menu, 'Tutorials', 'Creating Families'.
Post edited on 2005-12-08 09:36:11
thanks, then after that do i go into modeling then create to creat my own stuff?
You can either use the Modelling-Create tab to create an object in the project, or you can create a custom family using File-New-Family and choose the template you want to use (window, door, furniture, etc).
Post edited on 2005-12-08 11:38:39
As kesflower stated, make it a family if you want to keep it in your library to use again in any project. Use create if it's basically a one time shot custom to your current project.
ok, now how would i create something , say like a pool?
Search the forums, usually you can find the answers.
You should have tutorials in your help menu. Open Revit, click the Help pulldown - tutorials - Creating families, and then go through the tutorial. It doesn't take you through a pool, but it shows you the basics of using extrusions, sweeps, blends, etc and how to apply a material to your object. I hope this helps. The tutorials are wonderful for getting a grasp of what Revit can do, so if you've got the time, I'd go through all of them.
ok thanks, i rely dont get a lot of tme on revit, since i only use it for an hour a day at school, and the funny thing is the other day my teacher asked me to do a presentation on making your own objects. i want to get a student version though.
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects |
Fri, Oct 12, 2012 at 7:31:58 AM
Creating Objects |
Mon, Mar 8, 2010 at 9:24:52 AM
please help- tried everything to get objects to accept material... |
Thu, Apr 16, 2009 at 12:45:04 AM
Mass objects disappear in PDF |
Wed, Nov 29, 2006 at 9:17:49 AM
Placing objects in 2D, but cant see the in 3D. |
Fri, Jun 22, 2012 at 2:21:51 PM
