Forums >> Revit Building >> Technical Support >> applying tile to a floor
Sun, Nov 20, 2005 at 1:55:13 PM | applying tile to a floor
frs8
I am trying to apply tile to a bathroom floor, but it goes over the tub and toilet, etc. How do I get the hatch to go around the fixtures? Thanks, FRS8
Sun, Nov 20, 2005 at 3:54:21 PM | RE: applying tile to a floor
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Make sure the tub and toilets 3D visibilities are turn on in plan. Most likely the 3D elements are turned off in plan and a symbolic representation is shown. The problem with doing this is the tile pattern of the floor shows through. Alternate solution is to nest a detail component into the family containing a filled region to block out the hatch pattern (if the 3D element is a imported dwg and has excessive linework that you don't wish to show in plan)
Sun, Nov 20, 2005 at 4:23:08 PM | RE: applying tile to a floor
frs8
Thanks for responding. Where do you turn on the 3d visibility of the tub and the toilet? I looked in View Properties, Visibility but I didn't see anything for 3d specifically. Thanks, FRS
Sun, Nov 20, 2005 at 5:42:03 PM | RE: applying tile to a floor
Xane
I think that Mr Spot want to say to turn on visibility of family (category) that contain 3d toilet, etc or may be not ... or ...
Sun, Nov 20, 2005 at 8:44:35 PM | RE: applying tile to a floor
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Open the family. Switch to 3D view. select each of the elements. Click the visbility button. (refer image) Check its on in plan.
vinyl Floor tile in 3D view
Tue, Apr 24, 2012 at 3:39:15 PM
Raised Floor Tile Family
Thu, Aug 11, 2011 at 3:06:07 AM
Floor tile patters show under cabinets
Sun, Mar 25, 2007 at 11:08:03 PM
Make realistic tile pattern
Fri, Jun 25, 2010 at 9:43:53 AM
Floor/Wall tile layouts
Fri, Oct 7, 2005 at 2:17:29 AM
Page generation time: 0.2596
