Forums >> Revit Building >> Technical Support >> detail section
Sat, Dec 11, 2010 at 4:53:31 PM | detail section
lightshadows23
how can I do it?
i tried with doing a normal section then do callout on the edge of building. I put materials and put insert-exterior+ end-interior aswell..
so I did it but I cant see the wall/roof/ floor details on the pdf..
Sun, Dec 12, 2010 at 10:48:39 AM | detail section
Sorry but your question is not clear.  If you do a section callout as a detail, did you place that view on a sheet and create a PDF of it?
Sun, Dec 12, 2010 at 6:00:23 PM | detail section
lightshadows23
yes I did a section and then callou of section but when i save to pdf I cant see the details in wall and roof..
any idea?
Mon, Dec 13, 2010 at 7:26:18 AM | detail section
You don't save to PDF but you can print to PDF.
If you placed your callout on a sheet and printed that sheet, you should get whatever you see on the screen, unless your print driver is not up to date.  What PDF print driver are you using and have you upgraded it?
Thu, Dec 16, 2010 at 8:31:59 PM | detail section
lightshadows23
sorry i lost track of this..
well yeah i meant print to pdf.. but what i see on screen isnt what im supposed cause i see just the section without the interior details.. any other ideas of what i did wrong with this?
do i have to place on sheet to allow details show up?how?
Fri, Dec 17, 2010 at 1:14:18 AM | detail section
tim123
4 Stars: 19 Votes
Did you set the view detail level to fine?
Sat, Dec 18, 2010 at 2:03:48 PM | detail section
lightshadows23
yes..
what the hell is happening with this?mayeb its detail settings?
Sun, Dec 19, 2010 at 6:22:27 PM | detail section
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Check this link for detailing tips, and about your detail maybe is a VG setting, or a depth of view thats too close. Anyways watch the video
plan detail callout in section
Fri, Mar 29, 2013 at 12:48:11 PM
14
Section Blow up Details
Tue, Apr 29, 2008 at 4:38:22 PM
link detail drawing from another drafting view in the same project
Wed, Oct 12, 2011 at 11:14:00 AM
RAC 2009 - detail groups and section detail blow-ups
Fri, Mar 26, 2010 at 8:50:53 AM
Create Detail Section without tag?
Thu, May 22, 2008 at 2:38:50 PM
Page generation time: 2.7150
