77 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Two single doors in one frame, need to tag them individually
Tue, Apr 6, 2010 at 8:47:20 AM | Two single doors in one frame, need to tag them individually
arusso5
Revit Arch 2010
That probably didn't make a lot of sense, but we are working on a school project and our firm typically gangs classroom doors.  The doors make up is a 3' door with a sidelight and 1 1/2" hm frames in a 5' wide group.  We then typically will mirror that whole unit.  Sounds pretty simple right?  Well, the overall unit is 11' wide, meaning the connecting piece is like 1'-3".  This is also hm and the entire assembly ships to the field as an 11'-0" x 7'-4" unit.  The issue is that I need to tag the doors separately to correspond to the classroom number.  I have built the frame so that it flexs just fine, but how do I (or can I) get the unit to allow 2 separate door tags?
Any help would be greatly appreciated.
Tue, Apr 6, 2010 at 8:56:40 AM | Two single doors in one frame, need to tag them individually
Read the first similar post below:
Tagging both doors in same frame
Mon, Nov 3, 2008 at 10:18:38 AM
Windows and Doors Individually
Fri, Jul 15, 2011 at 3:14:21 PM
Making door frame match Wall thickness..
Thu, Jul 20, 2006 at 6:12:46 PM
Panel tags for glass doors with frame in curtain walls
Thu, May 1, 2014 at 7:51:48 AM
Material tag and doors
Mon, May 29, 2006 at 5:04:07 PM
Page generation time: 1.8028
