44 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimension grips...
Wed, Feb 3, 2010 at 9:32:16 AM | Dimension grips...
arusso5
I'm a bit embarrassed to ask this, because I may have altered something, but here it goes...
When I start to dimension my plans the grip point for selecting the first point of the dimension is miniscule.  I mean almost not visible.  Is there a way to change the scale of this?  Also, I only get a dot at this point, I do not get a face of wall, wall centerline option, I only get a tiny dot at wall corners.
What did I do and how can I remedy this?
Thanks in advance.
Wed, Feb 3, 2010 at 10:19:27 AM | Dimension grips...
Don't use linear dimension, use aligned.
Wed, Feb 3, 2010 at 11:21:26 AM | Dimension grips...
arusso5
Wow.  That was easy.  What exactly is the difference in the two types?  Why (or I guess when) would you use the linear dimension as opposed to the aligned?
Wed, Feb 3, 2010 at 11:25:02 AM | Dimension grips...
Let's say you have a diagonal wall but want to dimension it in the x and y directions....
Wed, Feb 3, 2010 at 11:31:48 AM | Dimension grips...
arusso5
If I already have a few strings of Linear dimensions... is there a way to convert them to Aligned?
Temporary Dimension Property Question
Tue, Aug 11, 2015 at 9:04:51 AM
Parameter Formulas and "Grips"
Wed, Nov 20, 2013 at 5:18:13 PM
Elevation's primary cut plane disappered and no grips
Tue, Apr 10, 2012 at 11:48:59 AM
Shape Handles (Grips) not showing in 3D
Sat, Jan 16, 2021 at 5:06:20 AM
Wall Layer Grips Missing
Wed, Dec 2, 2015 at 8:37:52 PM
Page generation time: 0.1522
