5 Users Online (3 Members):
Forums >> Revit Structure >> Technical Support >> PDF: WALL LINES ARE NOT CLEAR
5 Posts No Rating |
I have a problem: when I printed the sheet to PDF creater, and saved into my own drive, when I opened the PDF file, my wall lines are not clear, lines are not seperate, anyone can help? thanks so much.
Are you printing it to the correct scale, or to fit on a particular sheet? If you print an A1 sheet to 50% of it's size then this can occur. Also, you should be able to adjust the DPI setting in the PDF software, although I'm not familiar with PDF creater.
Black lines printing grayscale in PDF |
Fri, Oct 10, 2014 at 4:46:46 PM
Plotting PDF's |
Tue, Jul 21, 2009 at 4:18:05 PM
RVT 9.1 - plotting as PDF changes lines to halftone |
Tue, Jul 24, 2007 at 3:54:18 PM
Print to PDF |
Fri, Jan 23, 2015 at 6:47:45 AM
Wall Solid Fill Cut Pattern Jagged on PDF |
Fri, Apr 3, 2015 at 10:36:32 AM
