Forums >> Revit Building >> Technical Support >> Isolate Element
Mon, Jul 6, 2009 at 4:39:09 PM | Isolate Element
diesellam
Is there a way you can export the "Isolate elements" to the dwg format so that ONLY the isolated elements get converted but NOT the hidden elements?
Tue, Jul 7, 2009 at 1:15:41 AM | Isolate Element
tim123
4 Stars: 19 Votes
The 'Isolate elements' and 'Hide elements' are temporary and do not affect the drawing.  You can use them to 'Hide in view' and then export your drawing. (Use the temporary hide to hide the elements you do want to export, select everything else and 'Hide in view'.  Unhide the temporary hide elements and export the view.)
Tue, Jul 7, 2009 at 1:55:58 AM | Isolate Element
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
After isolating the elements click on 'Apply Hide/Isolate to View' as shown in the attachement, export to dwg and then you can undo it.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Wed, Jul 8, 2009 at 10:26:48 AM | Isolate Element
diesellam
Cool.  The trick is to click on "Apply Hide/Isolate to View" after you hide the unwanted ones.  Then export it as .dwg afterward.
It works, thanks a lot once again.
Wishing for improvements to Isolate by Category.
Wed, Sep 7, 2011 at 3:47:40 AM
Permanently isolate object in Revit?
Tue, Jul 10, 2012 at 8:14:50 AM
HOW TO ISOLATE A FLOOR PLAN FOR RENDERING ?
Mon, Aug 3, 2009 at 7:05:07 AM
Isolate Elements keyboard shortcut
Tue, Dec 15, 2009 at 4:41:48 PM
Isolate a group
Wed, Oct 23, 2013 at 7:02:50 AM
Page generation time: 0.0979
