Forums >> Revit Building >> Technical Support >> Wall Assembly
Fri, Jun 26, 2009 at 12:18:31 PM | Wall Assembly
diesellam
I'm not sure if somebody has done this before. When you model a wall, the wall is just a rectangular entity. But if I want to show the metal studs first, then the drywall, then the paint, how can I do that? Do I really have to physically model the studs, tracks, drywall separately in order to show them? How about the paint? Do I just make it a super thin layer? The reason I want to do this is to show the construction sequence in NavisWorks Timeliner. Thanks in advance.
Fri, Jun 26, 2009 at 12:29:33 PM | Wall Assembly
If you want all those components then you will have to model them.  Except for the studs, you could do each layer as a thin wall.
The studs you could model as a curtain wall without any panels.
I think you should find a better way.....
Edited on: Fri, Jun 26, 2009 at 12:30:31 PM
Fri, Jun 26, 2009 at 12:34:05 PM | Wall Assembly
tim123
4 Stars: 19 Votes
You can't turn off the separate layers of a wall, so you will have to model them separately.  I have no experience with Navis works, but a curtain wall might work where the studs are mullions and the plasterboard is shown as panels.
Wall Schedule showing Wall Assembly
Thu, Apr 29, 2010 at 1:26:27 PM
Existing wall assembly visable in New Construction phase
Wed, Nov 2, 2011 at 5:49:09 PM
Modifying vertical structure in edit assembly
Fri, Feb 9, 2018 at 4:27:20 PM
assembly
Mon, Apr 22, 2013 at 5:03:46 AM
Uniformat assembly codes
Thu, Jan 31, 2013 at 11:21:11 AM
Page generation time: 2.0077
