8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Stairs in RCPs
7 Posts No Rating |
My stairs are showing only as the overall boundry in reflected ceiling plans. This is happening even to stairs that are just treads (no risers or undermount), so if revit was just truly "looking" at the underside there should be lines arrayed at 10" or whatever.
what type of stairs are you using and please post example
I don't think that you can automatically do this. One method is to create a callout of the stair from the floor plan view, set the scale to be the same as the RCP, and place it beneath the RCP on a sheet. It will snap to the correct position.
7 Posts No Rating |
great work around Tim, thanks! It seems odd that revit wouldnt just show you what the stairs look like in actuality, but oh well
Room Tags in RCPs |
Sat, Feb 11, 2006 at 3:03:52 PM
Potlight Symbolic Lines showing up on other RCPs |
Mon, Mar 14, 2011 at 2:41:29 PM
Wrapping stairs |
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs |
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above |
Fri, Feb 17, 2012 at 1:44:46 PM
