Forums >> Revit Building >> Technical Support >> Window array
Mon, Mar 2, 2009 at 4:23:02 PM | Window array
wheelergc
I am trying to get the number of windows to vary depending on the width of the door.  I am stumped on how formulas really work. Sometimes they work great for me and other time like when i have edited someone elses family.  Things just don't seem to work.  Could someone look and see if they can figure out what i am doing wrong so i can try and learn this.  I seem to be getting asked to do a lot of families lately.
Tue, Mar 3, 2009 at 4:20:09 AM | Window array
tim123
4 Stars: 19 Votes
You need a formula parameter for the number of windows, such as length / spacing.
Tue, Mar 3, 2009 at 9:11:07 AM | Window array
wheelergc
Well that i know, but if you flex the family that does not work try that with the 12' Wide door.  Trying to get this family built so we can use it in future.  Which is what i think famalies are for.  I can't get the array to stay within the area of the door once it gets smaller
Wed, Mar 4, 2009 at 4:43:18 AM | Window array
tim123
4 Stars: 19 Votes
I have created a similar one which may help you (I had to do it in metric 'cos I can't get my head round the imperial stuff).  It has an invisible line in the middle of the window which I used to create the array.  Once I created the array I aligned and locked it to the reference lines that I set up.
Hope this helps.
Wed, Mar 4, 2009 at 9:35:03 AM | Window array
wheelergc
That is perfect.  Thank you very much for the help.  I was having such trouble getting it to work right.  I guess i still need to build more famalies and figure out all the little things that make them work.  Thanks again
Wed, Mar 4, 2009 at 10:21:21 AM | Window array
tim123
4 Stars: 19 Votes
No trouble - arrays in families can be tricky.  Just need to make sure you lock the start and end points.
window family array problem
Thu, Aug 5, 2010 at 2:46:17 PM
Changing Dimension object in Array
Thu, Jul 27, 2017 at 6:05:05 AM
Array Arc with an offset from centre
Mon, Jan 7, 2013 at 7:47:01 AM
Louvre Window
Wed, Jun 30, 2010 at 10:45:56 AM
array
Mon, Feb 26, 2007 at 3:09:19 PM
Page generation time: 0.3634
