Forums >> Revit Building >> Technical Support >> plan view cut plane inexplicably omits objects that it cuts.
Mon, Mar 2, 2009 at 11:29:43 AM | plan view cut plane inexplicably omits objects that it cuts.
rquist
Can't think of any reason why my rail spindles and rail newel posts aren't visible in plan view.
Cut plan is set at -8" from my finished floor revealing the deck joists, but doesn't include anything pertaining to the railing.  The newel shown on plan view is an independant newel that was inserted as a seperate item. The railing box is checked in view view graphics override dialogue box so I know it's turned on there.
Any help???
 Also, I'm sure there is a way to add intermediate newels.  I've only seen options for starting and ending newels.
Mon, Mar 2, 2009 at 11:32:20 AM | plan view cut plane inexplicably omits objects that it cuts.
rquist
still using 2008
Tue, Mar 3, 2009 at 3:54:46 AM | plan view cut plane inexplicably omits objects that it cuts.
tim123
4 Stars: 19 Votes
The rail may have ben switched off individually.  Click on the light bulb to see if it is overridden.  If not, where is your floor level.  Try and raise the level of your cut plane and top of the primary range.
In order to add intermediate posts you have to define the whole pattern, so in your case you will define say 15 balusters and then the post.  This becomes the pattern that repeats.  Play with the other settings in the Baluster Placement dialogue box such as the excess length fill to achieve what you want.
Tall Objects Above Cut Plane: Bleachers
Wed, Aug 20, 2014 at 10:16:06 PM
Cut plane problems with Families - Revit 2013
Tue, May 21, 2013 at 2:29:27 PM
Casework in Plan View
Sun, Feb 19, 2017 at 11:38:54 PM
Cut plane for doors and widows different from plan!!
Wed, Oct 18, 2006 at 8:41:37 AM
Cuts through Ramps in plan view
Mon, Dec 19, 2005 at 2:33:11 AM
Page generation time: 1.9555
