Forums >> Revit Building >> Technical Support >> Tracking generic masses
Thu, Feb 19, 2009 at 2:27:09 PM | Tracking generic masses
doubleclick
I've created a generic mass to lay out some stonework. I want to make sure I am using it correctly so we can add information to it later. There will be approximately 60 unique block shapes. I need to be able to create a schedule that lists each block and tracks how many are used in the project. I also need it to keep track of the area of the front face so I can tell the quarry how much we need. How do I add the necessary properties to the block? I've attached the file I've created.
 I saw someone mentioned a tutorial section. Is there one here on RevitCity?
Product name: AutoCAD Revit Architecture Suite 2009Product version: 2009.0.0Product service pack: Web Update 3 Service Pack
Fri, Feb 20, 2009 at 2:33:15 AM | Tracking generic masses
tim123
4 Stars: 19 Votes
Create the object in Revit as a family and give it parameters for height and width.  You will be able to get all the information that you need from it, or add it later.  Looking at you object, it would appear that it was created in different software and imported as a mass.  You will not be able to get schedule information from it.
Revit Time Tracking
Wed, Nov 16, 2016 at 8:01:10 AM
Compare Two Masses in Schedule
Fri, Jan 15, 2016 at 3:24:28 PM
Masses Don't Print?!?
Thu, Feb 24, 2011 at 2:47:51 PM
Void Masses
Fri, Oct 3, 2008 at 4:11:06 PM
generic model family not cutting in section
Tue, Jan 11, 2011 at 7:14:50 AM
Page generation time: 0.0742
