53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Help. I can't create this roof
Thu, Feb 5, 2009 at 7:38:06 PM | Help. I can't create this roof
alc112
Hi!
I think I've been trying for more than 2 hours and I can't figure out how to create this roof:
 [img]http://xs136.xs.to/xs136/09064/roof792.jpg[/img]
I've tried with lines defining slopes (which was the best option), then the arrows and the flash roof to use those extra options.
Can someome tell me how to create it?
Thanks a lot!!
Thu, Feb 5, 2009 at 9:27:21 PM | Help. I can't create this roof
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi alc112, you are talking about something like this???.....only one observation, your roof plan doesn't "match" with the elevation below....
Thu, Feb 5, 2009 at 9:33:27 PM | Help. I can't create this roof
alc112
YEs that's what I try to do.
One roof is placed 60 cm  upper  than the other.
Thu, Feb 5, 2009 at 9:39:13 PM | Help. I can't create this roof
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi alc112, have you read in the Revit help section: Roofs :Intersecting slope lines at different heights???....saludos hasta Argentina.....
Edited on: Thu, Feb 5, 2009 at 10:31:30 PM
Fri, Feb 6, 2009 at 3:48:20 PM | Help. I can't create this roof
tim123
4 Stars: 19 Votes
I created something similar using two different roofs and joining them.  See image.
Fri, Feb 6, 2009 at 4:15:04 PM | Help. I can't create this roof
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Yeah, that's the way. BTW-interesting image Tim......
Fri, Feb 6, 2009 at 4:30:26 PM | Help. I can't create this roof
tim123
4 Stars: 19 Votes
Thanks for that Ernesto.
Fri, Feb 6, 2009 at 10:03:33 PM | Help. I can't create this roof
ksig1969
ksig1969 Avatar
I have a roof myself that has been giving me some difficulty.  This project has two bearing heights (9'-4" & 12'-0"Winking  I attached a pdf of the original plans of this house.
 By the way I am using Revit '09
I am new to Revit and I am trying to teach myself.  I have beed using CAD for years.
Thanks for the help!!!
 REVIT ARCHITECTURAL 2009
~ Pat
Cape Coral, FL.
·´¯`·.¸.·´¯`·.¸ >< ((((º>
. ·´¯`·.¸ >< ((((º>
Fri, Feb 6, 2009 at 10:07:33 PM | Help. I can't create this roof
erland73
erland73 Avatar
4.5 Stars: 85 Votes
No file attached......
Fri, Feb 6, 2009 at 10:12:23 PM | Help. I can't create this roof
ksig1969
ksig1969 Avatar
Ok one second I have to compress the file
Edited on: Fri, Feb 6, 2009 at 10:31:25 PM
~ Pat
Cape Coral, FL.
. ·´¯`·.¸ >< ((((º>
Fri, Feb 6, 2009 at 10:54:05 PM | Help. I can't create this roof
#11
ksig1969
ksig1969 Avatar
Ok hopefully this will upload now
~ Pat
Cape Coral, FL.
. ·´¯`·.¸ >< ((((º>
Sat, Feb 7, 2009 at 7:16:34 AM | Help. I can't create this roof
#12
4 Stars: 201 Votes
Do it in One Piece if you want or you can create several roofs and Join them....
Sat, Feb 7, 2009 at 8:22:21 AM | Help. I can't create this roof
#13
alc112
I could create it with 2 separate roofs and then I used join geometry.
I tried what Typhoon shows but that is not what I was looking for (Anyway, it's good to know)
Sat, Feb 7, 2009 at 8:47:15 AM | Help. I can't create this roof
#14
ksig1969
ksig1969 Avatar
Thanks for the help Typhoon.  I figured out how you did the roof so I am a lot closer.  The only problem is the front overhang isn't exactly correct.  I made a closeup of the overhang see attached.
~ Pat
Cape Coral, FL.
. ·´¯`·.¸ >< ((((º>
Sat, Feb 7, 2009 at 9:17:56 AM | Help. I can't create this roof
#15
4 Stars: 201 Votes
Just like I said before "or you can create several roofs and Join them...."
Create Roof Family Object
Mon, Nov 21, 2005 at 7:10:42 PM
Roof Phases
Mon, Jul 10, 2006 at 3:54:43 AM
Roof by footprint won't work in view
Fri, Jul 9, 2010 at 12:10:55 AM
Gap in Roof
Tue, Oct 4, 2005 at 1:33:08 AM
single roof plane of multiple slopes
Mon, Jul 11, 2005 at 8:09:38 PM
Page generation time: 1.2358
