463 Users Online (52 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Structure >> Technical Support >> Can you create ducts in Revit structure?
Sat, Jan 10, 2009 at 1:37:38 PM | Can you create ducts in Revit structure?
hhwse
I have a project I am currently designing and there are several areas with large mechanical truck lines that I would like to put into my model so I can keep track of them.  Can I do this?
Fri, Jan 16, 2009 at 3:56:39 PM | Can you create ducts in Revit structure?
emgeeo
3.5 Stars: 7 Votes
I would recomend in-place families:
1.  Under the Modelling tab, select the 'Create...' button.
2.  Click on the 'Show categories from all disciplines' checkbox
3.  Use a category of your choice; Air terminals, Generic Model, etc.
Extrusions-based geometry should do just well.  If you don't know what to do next let me know.
Sat, Jan 17, 2009 at 12:28:21 AM | Can you create ducts in Revit structure?
radhikase
hhwse,
Make line-based generic model families with reqiured profiles and parameterise them for length, depth and width/radius. You can then use these for the ducting. You may have to use connectors, because I have found that the line-based families don't curve well. I am using Revit Architecture 2009 for making the entire Mechanical ducting for a 53,000 SF school building. Maybe the organisation would buy Revit MEP after this.
Radhika.
Sat, Jan 17, 2009 at 1:01:42 AM | Can you create ducts in Revit structure?
hhwse
thanks i will give it a try.
Creating Families
Wed, Sep 24, 2008 at 5:06:16 PM
"System Color Schemes" not regular color schemes in Elevation or Section views
Mon, Mar 22, 2010 at 6:00:00 PM
Linked CAD ducts/pipes not showing up in Revit Structure 2013
Fri, Jul 10, 2015 at 8:36:42 AM
13
Ducts/Pipes categories during export/import from Revit to IFC
Mon, Jun 18, 2018 at 11:54:16 AM
I can't load anything from my library.
Thu, Jul 25, 2013 at 10:16:10 AM
Page generation time: 2.7500
