Forums >> Revit Building >> Technical Support >> Wall join display
Mon, Sep 15, 2008 at 12:05:35 PM | Wall join display
brandon684
Is there any way to get rid of the line that gets put between walls when you change wall types? Like when you draw with 6" outside walls and 4" inside walls.
Tue, Sep 16, 2008 at 3:08:26 AM | Wall join display
tim123
4 Stars: 19 Votes
If you click on the wall a blue point appears at each end.  Right click on this and choose 'allow join' and the walls should clean up.
Tue, Sep 16, 2008 at 4:53:47 PM | Wall join display
brandon684
The walls were being allowed to join, but there was still a line showing up between them. But I figured out what I wanted. If anyone else cares, you go to view properties and turn off the 'common edges' on the walls.
Wall Join Display
Thu, Oct 14, 2010 at 12:52:50 PM
Any way to set Wall Join Display to not clean any walls?
Mon, Sep 19, 2011 at 1:19:19 PM
Clean wall join
Sat, Apr 20, 2013 at 3:30:48 AM
11
Wall join options
Wed, Mar 23, 2011 at 7:46:49 PM
90degree wall join
Sun, Aug 20, 2006 at 9:08:54 PM
Page generation time: 1.3053
