20868 downloads
15564 downloads
13236 downloads
Dual driven underhung bridge crane, designed to carry 5 tons. Is ground based, with runway beams adjustable on both sides of bridge. |
4232 downloads
Adaptive moving walk.
How to use:
load to proyect, hit load on workplane, pick or select workplane, click start point, click endpoint.
Go to elevation, and set the levels it will conecct.
Its not fully parametrized in the some dimensions, only lenght, width and height, and its geometry is simplified to have a bunch of these on your proyects.
Feel free to rate and modify |
16248 downloads
StandAlone CargoElevator S (2Door)
Metric CargoElevator S (2Door) with DIM & Material parameters and dimension Guide
Visit our website AgileRevit.com for more families |
No rating |
3005 downloads
Wall based ElevatorDoorA
Metric ElevatorDoorA with DIM & Material parameters and dimension Guide
No rating |
3352 downloads
Wall based ElevatorDoorB
Metric ElevatorDoorB with DIM & Material parameters and dimension Guide
No rating |
12 downloads
1255 downloads
AGRV_GENM-SPCQ_Escalator_電扶梯
Metric Escalator (Generic model) with DIM & Material parameters and dimension Guide, base on mitsubishi escalator.
The angle of the escalator are also drived by parameter.
Visit our website https://www.agilerevit.com/ for more free families |
2868 downloads
AGRV_GENM-SPCQ_MovingWalkwaySlope_傾斜式自動步道
Metric MovingWalkway (Generic model) with DIM & Material parameters and dimension Guide.
1555 downloads
StandAlone PassengerElevatorA (Side Counterweight)(2Way)
Metric PassengerElevatorA with DIM & Material parameters and dimension Guide
No rating |
261 downloads
No rating |
148 downloads
No rating |
137 downloads
No rating |
3117 downloads
No rating |
2200 downloads
NON-parametric Luggage trolley (1200x750mm) used in hotels - brass finished with wheels. (Made from Furniture family) |
No rating |
8350 downloads
Caged Ladder drawn by Jeff Rath in Revit side exit to the left |
4455 downloads
Caged ladder drawn by Jeff Rath in Revit side step off right |
No rating |
2386 downloads
Hydralic Glass Elevator. Mechanical Room Basement. Elevator is at base level. Open for family/component editing. Use of another creators lighting (see stair light). Currently set for 5 levels each 13'-4" and basement 6'-0". |
52023 downloads
A reworked version of the file 3d_Revit_Tree_7metres_high_3943Its taller and wider and reshaped |
No rating |
6750 downloads
4660 downloads
Edited wall-based lift |
41469 downloads
Electric Elevator |
Product Version: Revit Building 5.1
172427 downloads
Passenger 2000 to 4000 and Service 4000 to 5000 elevators all in one family. This is a parametric elevator that can have up to 10 stops. There are many paramaters that you can control like amount of stops, distance between stops, frame size, etc. |
98848 downloads
door opens from center |
47725 downloads
door opens from side |
No rating |
16049 downloads
KONE MonoSpace® 700 20 floor KONE elevator
KONE MonoSpace® 700 Elevador de 20 pisos |
3301 downloads
Detail Item of Elevator buttons. It is 2D figured a 3D one was over kill. In the instance panel there is 2 parameters X/Y Array for the count of buttons.
This is a really simple family but hope it helps
smh |
No rating |
1259 downloads
Update to my previuos post |
Product Version: Revit Building 9.1
115732 downloads
