Metal Building - Rigid Frame with Adjustable Ridge
11758 Downloads
5 Stars from 2 Votes
Metal building framing.  The ridge can be offset using the "Ridge Leg" parameter.  If the eave height and slope are set correctly, the other height is automatically adjusted.
CSI Division: 05 12 00 Structural Steel Framing
RevitCity Division: Structural > Framing > Steel
Uploaded By: nachtwolf
Uploaded On: Thu, May 31, 2007
Mon, Aug 18, 2008 at 12:14:49 PM
JMNeel
Joined Sat, Jun 16, 2007
Should this work in Revit Architecture 2009?...
Wed, Apr 1, 2009 at 3:41:14 PM
cstricklanddesign
Joined Wed, Apr 1, 2009
Component will not load
Thu, Feb 27, 2014 at 9:17:30 AM
dstag
Joined Mon, Jun 25, 2012
If you want the frame to remain symmetrical, edit the overall span parameter to = 2* ridge length.
Works great thanks.
Page generation time: 0.3878
