MIFAB® MI-HUB-TRCC - SHIELDED TRANSITION COUPLINGS - COPPER TO COPPER OR PLASTIC
16 Downloads
MIFAB® Series MI-HUB-TRCC (specify size) shielded transition couplings are manufactured with gaskets made from neoprene compound that meets the requirements of ASTM C564 housed inside a Type 300 stainless steel shield. Two Type 300 stainless steel clamps tightened with 5/16” Type 300 stainless steel hex head screws surround the shield to provide the sealing force.
The MI-HUB-TRCC Series of shielded transition couplings are tested and certified to ASTM Standard C1460 and CSA Standard B602 and listed with IAPMO. All models are listed to the National Plumbing Code of Canada and relevant Canadian Standard(s) and bear the cUPC mark of conformity. Non constant temperature rating is 140 F.
Uploaded By: mifab1
Uploaded On: Thu, Mar 11, 2021
Page generation time: 0.0075
