MIFAB® F1640 - ISOLATION FLOOR DRAIN WITH 9” ADJUSTABLE STRAINER TRACTOR GRATE
26 Downloads
MIFAB® Series F1640, 9” (229) diameter blood and water drain set consisting of two lacquered cast iron bodies with anchor flange and weepholes. One body furnished with a 9” (229) diameter lacquered cast iron adjustable top assembly and special duty ductile iron grate. The other body furnished with a solid gasketed ductile iron cover with lift ring. The top assemblies are interchangeable with either body.
(For membrane floors, add Suffix -C for the membrane clamp.)
Uploaded By: mifab1
Uploaded On: Wed, Mar 10, 2021
Page generation time: 0.0057
