Livers Bronze Co Railings
3387 Downloads
http://www.liversbronze.com/revit-files/
Revit files are now available for all Livers Bronze railing systems. Simply complete the form and submit your Revit file request. We will then send you an email with a link to download the Revit file. Once the file is downloaded, you can load it into the desired project model by following the provided instructions that are specific to each railing system.
The Livers Bronze Revit family systems contain customizable parameters which allow control of the height, rotation and visibility for all of the handrail’s balusters, glass lines and supports. Once unpinned, balusters, glass lines and support elements slide on the host rail to the desired location. Grips are provided for maximum adjust-ability as well as the visibility option of turning them on or off, or copying if needed. We have also incorporated structural alerts when certain elements have exceeded their design parameters in order to assure proper layout requirements. Once you have one element the way you want it, you also have the option to match properties to quickly repeat the desired look throughout your project.
Systems available:
Struct-U-Rail Button Blok MirageEmpire SingularIdentic Plank Matrix Razor IconAmerican 20/20 Belmont FontanaPanel
Keywords:
Glass Panel Railing, Cable Railing, Panel Railing, Perforated Panel Railing, LED Railing, Handrails, Wall Railing, Single Line Railing
CSI Division: 97 50 00 Railings RevitCity Division: Stair Components > Railings
Product Version: Revit Architecture 2014 |
Uploaded By: LiversBronzeCo
Uploaded On: Mon, Oct 31, 2016 Original Creator: Livers Bronze Co
Previous Versions
Product Version |
Credit |
Uploaded On |
Last Edit |
Livers Bronze Co |
Mon, Oct 31, 2016 |
Livers Bronze Co |
Mon, Oct 31, 2016 |
Livers Bronze Co |
Mon, Oct 31, 2016 |
Livers Bronze Co |
Mon, Oct 31, 2016 |
Livers Bronze Co |
Mon, Oct 31, 2016 |
Wed, Apr 1, 2026 at 8:18:36 AM
Joined Tue, Feb 18, 2025 No rating This user is offline |
Salut, en cherchant des solutions pour mieux gérer mes investissements en crypto, je suis tombé sur Crypto Fin AI https://finai-invest.com, et ce qui m’a vraiment intéressé, ce sont les outils spécialement conçus pour les utilisateurs de Belgique, offrant des analyses claires et des recommandations adaptées. Au début, j’ai testé quelques fonctions et rencontré des erreurs mineures, mais après avoir suivi les instructions fournies par la plateforme, j’ai réussi à ajuster ma stratégie et obtenir des résultats positifs. Maintenant, j’utilise régulièrement cette application pour suivre le marché, prendre des décisions éclairées et optimiser mes investissements en crypto avec plus de confiance.
