Forums >> Revit Building >> Technical Support >> How do i created a curved ceiling?
Thu, Jan 17, 2008 at 3:47:22 PM | How do i created a curved ceiling?
twhisker
2.5 Stars: 5 Votes
I created a curved roof with the roof extrusion tool.  Now i need to place a ceiling 9" below and parallel to it.  So far, all i can see is to create a flat ceiling.  Any ideas??  RAC 2008.  thanks.
Revit Architecture 2010
Thu, Jan 17, 2008 at 4:13:02 PM | How do i created a curved ceiling?
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
You can create this as an inplace family.
Go to the create command on the modeling tab and when a dialog pops up select ceiling.
After that you can specify a solid extrusion and pick a work plane to draw on and then you will be able to create any shape you want.
For a workplane I usually use a grid, but you can also place a reference plane to work on.
HTH
Brett
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Thu, Jan 17, 2008 at 4:25:08 PM | How do i created a curved ceiling?
twhisker
2.5 Stars: 5 Votes
Thanks Brett - that worked!!  The component doesnt seem to act like a ceiling though as I have assigned a surface pattern to the other ceiling objects.  Doesnt seem to know its a ceiling.  I just used a manual override and gave it a surface and it all came in - oddly though but that is probably because it is a concave ceiling.
Fri, Jan 18, 2008 at 8:24:19 AM | How do i created a curved ceiling?
brettgoodchild
4 Stars: 17 Votes
Glad that worked out for you.
You are right, it doesn't have a lot of the options that a ceiling would that was drawn with the ceiling command but it will play host to light fixtures and what not and you can assign materials to it.
Again, glad I could help out.
Brett
                             ~ Abraham Lincoln
Thu, May 19, 2016 at 12:28:14 AM | How do i created a curved ceiling?
us3rn4m3
Many thanks, it worked perfectly!!
Curved Ceiling
Wed, Dec 9, 2009 at 10:46:05 AM
Wall and Ceiling Issues
Tue, Jan 20, 2009 at 7:50:47 PM
recessed Lighting for a curved ceiling or roof ceiling?
Fri, Jun 27, 2008 at 11:06:24 AM
molding onto curved ceiling [ 1 2 ]
Wed, Mar 2, 2011 at 11:54:43 AM
17
Curved Ceiling lights come in upside down
Thu, May 14, 2015 at 12:57:27 PM
Page generation time: 0.3758
