Forums >> Revit Building >> Technical Support >> Flex Family Based on Phase
Fri, Jan 11, 2008 at 1:07:47 PM | Flex Family Based on Phase
anthonywalker
Does anyone know if there is a method available to create a family that will flex based on the Phase of the view it is being displayed in? Case in point:Architecturally when working within an existing building, I traditional show Existing doors with a 45deg. open swing while new doors are shown at 90deg open.  From a model and data perspective these doors are the same and should remain the same with no change to family type, but the SYMBOLOGY of the door needs to change based on the phase of the drawing being viewed.  I know that I can set up an Instance Parameter that would control the Open swing, but cannot figure out how to drive this parameter based on Phase of the View.Via the phase graphic override, I can change the line graphics (weight, color, style, material) but am looking to push this a bit further....
flex duct tag
Thu, Jun 11, 2009 at 9:27:25 AM
Window family won't flex
Thu, Jan 13, 2005 at 7:42:12 PM
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:37 PM
No Shaded Flex Duct??
Tue, Nov 20, 2012 at 11:57:19 PM
Revit 2013 family from wall based to flor based
Mon, Feb 4, 2013 at 6:56:51 AM
Page generation time: 1.1853
