Forums >> Revit Building >> Technical Support >> formulas & schedule problem
Thu, Jan 10, 2008 at 12:36:48 AM | formulas & schedule problem
freeman
i need to count number of bricks in every wall for Bill of Quantity schedules.what's the formula if there should be like 24 bricks for every square area of wall. ..i cant seem to use (*) when i use this syntax in calculate value in schedule properties of wall in revit2008.i wanted to multiply lenght or area by 24. pls help. thank you
Thu, Jan 10, 2008 at 1:18:43 AM | formulas & schedule problem
freeman
also,i get the message "inconsistent units" everytime i use multiply (*).can u guys write me an example formula here? ...say for total cost of walls, number of hollow bricks on hte wall,paint volume ...stuff like that. ...thanks again.i'm really just a newbie with formulas & schedules =)
Thu, Jan 10, 2008 at 8:20:16 AM | formulas & schedule problem
coreed
coreed Avatar
4 Stars: 16 Votes
lookat Mr.Spot post in this thread, it may be of help
http://www.revitcity.com/forums.php?action=viewthread&thread_id=556
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jan 10, 2008 at 8:21:33 AM | formulas & schedule problem
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Here is the formula I use for Cost per Sq Ft. This is a calculated value in the schedule...
Total cost = (Material: Area/1) * Material: Cost
Any time you are doing a calculation you have to make sure that each of the parameter are the same Unit type. That is why I used the (Material: Area/). This converts the number into a simple Integer so I can multiply it by the Material Cost.
You could use something like this to do the Number of Bricks in a wall. You may have to play around with the formula but it should get you started.
Sun, Jan 13, 2008 at 2:24:09 PM | formulas & schedule problem
freeman
thanks coreed & jameshgrimes. i did try all u said.m getting it bit by bit.thanks a lot.but i guess everyone's gonna appreciate it if someone out there would have the time to write template formulas =) ...thanks again!
Calculating two Formulas on the same row in a Schedule
Fri, Dec 17, 2010 at 7:22:56 AM
Formulas for Schedules
Wed, Jul 22, 2009 at 3:31:28 PM
Formulas in Schedule
Thu, Feb 27, 2014 at 7:41:30 AM
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:05 PM
14
Parameter formulas losing calculated values
Wed, Jun 17, 2015 at 2:23:19 PM
Page generation time: 0.8580
