456 Users Online (19 Members):
- Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM |
Forums >> Revit Building >> Technical Support >> Dimensioning to the mid point of a roof.
43 Posts No Rating |
Hi, well i'm getting close to wrapping up some prelims for a design panel. my problem now is getting revit to dimension building height. in acad we simply dimensioned to the peak and top of the fascia, then from the mid point of the dimension line down to grade. i tried to do this in revit, and had to draw some ref lines, and then figure out the middle of the roof, but i couldn't get revit to dimension to the mid point of the roof or the dimension. anyway i worked around it, and have it temporarily solved, but i was wondering if there is an easier way? thanks here's a pic of what i want it to do. my 'workaround' if you will
Edited on: Tue, Jan 8, 2008 at 5:29:48 PM
Revit user since 2008. |
I do this by drawing a reference plane at about the center of the roof. I then add a dimenension from the ridge, to the ref plane, to the eave and toggle the equality option. This locates the ref plane at the midpoint. I then add the dimension from grade to the ref plane. You can delete the EQ dimensions and maintain the constraint if desired and then add the dimension from peak to eave, if that is the look you are trying to get. HTH.
thanks lizard, that's gonna have to do for now. thanks Tim
Warthog |
Mon, May 9, 2011 at 12:25:13 PM
dimensioning to line mid point |
Wed, Aug 27, 2008 at 9:37:51 AM
Disallow wall join of a mid-end face |
Mon, Feb 11, 2008 at 5:54:01 PM
Topography Elevation from Project Base and Survey Point is Incorrect |
Thu, Jan 29, 2015 at 10:32:24 PM
Roof by Face and Wall by face tools |
Tue, Jan 28, 2014 at 6:31:03 AM
Members: | 2175249 | Objects: | 23399 | Forum Posts: | 152401 | Job Listings: | 0 |
