167 Users Online (165 Members):
Forums >> Revit Building >> Technical Support >> String Parameter outputs together in a formula
Is it possible to combine several outputs from different formulas to create a product number? See the attached casework family. I would like to get the Model to read out 1"ID-Hand""ID-Type""ID-Width""ID-Height""ID-End Panel"-"ID-Finish" so that the default product number would be 102C432-U. I was thinking something along the lines of IF(Manufacturer="WIC","101",if(Manufacturer="FH",PLACE STRING HERE,"ERROR" ) On a related note it would be nice if there was a way to have the "ID-Hand" parameter read 02 by default but change to 03 if the flip control was used. Any thoughts or ideas? Thanks Nick -- Stupid smilies -- Try this fileEdited on: Mon, Jan 7, 2008 at 4:44:29 PM
Edited on: Mon, Jan 7, 2008 at 5:34:57 PM
Unfortunately You can't yet add a parameter to a text field... Nor is there a command similar to "concatenate" in excel which would enable you to do this. One for the wishlist. Only solution would be to create a tag that had the items setup as shared parameters situated close together to effectively look like one code... Or manual data entry.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Thats what I ended up doing. Its just a pain to add 8 shared parameters to each file and then get the numbers to not run over.... Oh well just another work around for now. Thanks Nick
String Values in Formulas |
Wed, Dec 4, 2013 at 10:38:12 PM
Revit Reporting Parameter |
Wed, Aug 7, 2013 at 11:17:04 AM
Formula for Manhole Family |
Fri, Oct 5, 2012 at 11:18:05 AM
Add size_lookup formula via Revit API |
Mon, Mar 21, 2016 at 8:53:25 AM
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
Members: | 1995602 | Objects: | 22885 | Forum Posts: | 152175 | Job Listings: | 3 |
