Forums >> Revit Building >> Technical Support >> Finishes
Sat, Jan 5, 2008 at 2:33:47 PM | Finishes
askask
Does anyone know how to change the carpet color and wall colors? thanks
Mon, Jan 7, 2008 at 8:18:09 AM | Finishes
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Those items are controlled by the Materials in Revit. You can set up your own custom materials by going to...   Settings-->Materials. To create a new material click on an existing Material and click Duplicate. You can then rename and attach your custom images or use an Accurender Material. To apply the material to walls and floor you will need to select the item and go to the element properties of that item. You can then click Edit/New in the dialog box and go to the Structure button. In the structure properties box there is a column for Material where you can add your custom material.
Internal Wall Finishes
Tue, Mar 25, 2014 at 4:18:18 PM
floor finishes
Thu, Jul 1, 2010 at 7:19:37 AM
Creating a wall finishes schedule, and coding wall finishes on elevations
Fri, Jun 1, 2012 at 4:06:32 PM
wall finishes by room
Tue, Apr 19, 2005 at 11:40:25 AM
Floor Finishes not showing up in Revit 2013
Thu, Dec 25, 2014 at 5:52:36 AM
Page generation time: 0.2593
