87 Users Online (86 Members):
Forums >> Revit Building >> Technical Support >> Adding color to a Profile
I used a profile to create hardiplank siding on a residential structure. I want this siding to be a particular color (currently it is white). How do I change the color for the siding and leave the other exterior material (such as stucco) to be different colors?
Are you using this profile as a sweep on a wall? If so, you can assign your material when you set up the sweep. If you are are adding this profile to the wall type as a sweep, you can set the material up there.
Adding parameters in a slab edge profile |
Mon, Aug 20, 2018 at 10:44:27 AM
adding radius edge to floor slab |
Wed, Jul 21, 2010 at 7:47:29 AM
Slab Edge Profile... Except Up... |
Wed, Nov 11, 2009 at 7:00:24 PM
adding a roof cornice profile |
Wed, Feb 17, 2010 at 7:01:05 AM
Adding an area color type |
Mon, Nov 3, 2014 at 7:05:20 PM
Members: | 1996405 | Objects: | 22885 | Forum Posts: | 152178 | Job Listings: | 3 |
