Forums >> Revit Building >> Technical Support >> Remove line where two walls on different levels meet?
Thu, Nov 29, 2007 at 9:12:07 AM | Remove line where two walls on different levels meet?
OktoberFire
OktoberFire Avatar
in my section i have 2 walls, below ground level and above, essentially it is one wall but i have 2 bits on each level.
my problem is, in section i have a line where they join - can i remove this?
Thu, Nov 29, 2007 at 9:19:32 AM | Remove line where two walls on different levels meet?
aandr001
4.5 Stars: 6 Votes
You can use the linework tool (upper left hand button that looks like a fountain pen).  Click on it, go to the pulldown menu and select "Invisible Lines" and then click on the line.  You may need to do this a few times because you are actually removing lines from both walls and from the far end of both walls.  If you ever need to undo this condition later you just click the linework tool again and from the pulldown select "By catagory" for the linetype and then click on the lines again to restore them to thier former appearance.
Thu, Nov 29, 2007 at 9:23:07 AM | Remove line where two walls on different levels meet?
OktoberFire
OktoberFire Avatar
thank you for the fast response and it works perfect :D
Joint between walls
Fri, Aug 30, 2013 at 1:37:29 PM
Levels.
Thu, Feb 11, 2016 at 8:55:59 AM
Interior elevation - walls next to each other are showing where they meet
Tue, Jun 21, 2011 at 12:26:23 PM
walls look different on different levels
Thu, Mar 11, 2010 at 2:38:19 PM
Single Floor with multiple levels
Tue, May 14, 2013 at 10:24:40 AM
Page generation time: 0.9630
