68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Create Stone Hatch pattern
Ok I've tried searching High and Low for this, and can't find any specific answer. I tried to download and use Hatchkit, but didn't find it too useful. Is there a way to create a hatch .pat file from a .dwg or .dxf? I have attached a .dxf of what I'm trying to create. Thanks so much, Lorne
Denver, CO
Revit Architecture |
I have attached a very nice lisp routine for you, you need Acad for it to work. use: appload to locate the lsp file and load it into your drawings use: drawhatch to start drawing use: savehatch to save a .pat file it is very simple and effective
Edited on: Wed, Nov 28, 2007 at 7:33:28 PM
Great Eldados! I knew there was an easy way! Is there anyway to make the drawing template more than a 1x1 square? That would be great. Thanks. Lorne
Denver, CO
one more thing. Where does it save this file??
Denver, CO
the default is 1x1 if you want to change it, I believe you will have to change the lisp. the file saves to where ever you want...
Importing the above DXF to HatchKit yielded 2 stone pattern blocks that could be directly turned into hatch patterns, one of which is attached, ready for loading to Revit at full scale. There's no need to redraw the pattern template to cover a 1x1 repetition.
Hugh Adamson
www.hatchkit.com.au |
Hugh, May I just say you Rock! This is exactly what I needed. Thanks so much!
Denver, CO
Stone Hatch Patterns - Looking for a good source. |
Sat, May 4, 2013 at 4:59:24 AM
hatch pattern not printing |
Mon, May 8, 2017 at 12:56:51 PM
Stone work help |
Thu, Nov 15, 2007 at 5:10:45 PM
Hatch pattern |
Tue, Jan 13, 2009 at 10:23:47 AM
Easy Stone Hatch patterns (Stone CAD) |
Wed, Dec 3, 2008 at 10:40:50 PM
Members: | 1994335 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
