Forums >> Revit Building >> Technical Support >> Movable Text in Objects
Tue, Feb 22, 2005 at 10:25:09 AM | Movable Text in Objects
arhit33
I am a new user to Revit and I have converted our entire office from ADT to Revit. We are moving right along with it as far as the modeling, but have come to somewhat of a halt with the documentation part. What I am wondering is, is there a way the create a family such as an Outlet with GFI for the text, but have the text that it can be rotated or moved? The GFI Outlet that comes with the program has a label with it, but when placed on north side of a wall the text is upside down. We normally like the text to remain horizontal. Any suggestions?
Tue, Feb 22, 2005 at 5:16:21 PM | RE: Movable Text in Objects
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I don't believe you can modify the text in a family once its been loaded in the project at the moment. It may be an idea to remove the text then create a tag for the category of the element that displays the type name. Then you could modify the tags as you see fit. HTH.
Wed, Feb 23, 2005 at 7:14:30 AM | RE: Movable Text in Objects
fazerneil
4 Stars: 5 Votes
Can you not create a family and insert text within family as a parameter and also add a rotation perameter to text where you can input angle once imported ? Have not tried it yet but it can be done for lines etc on door swings.
Movable objects in families
Wed, Jun 25, 2008 at 3:29:12 PM
dimension text un-movable when crop regions applied to a wall section?
Wed, Feb 14, 2007 at 8:40:59 AM
HELP PLEASE
Mon, Feb 4, 2008 at 11:12:40 AM
View Title - Editable text labels
Wed, Sep 8, 2010 at 2:57:11 PM
Imported Text Boxes from AutoCAD to Revit 2011 New Line Shifts Text Upward
Wed, Dec 29, 2010 at 5:27:08 PM
Page generation time: 1.0078
