Forums >> Revit Building >> Technical Support >> Printing/Plotting Problems
Wed, Nov 14, 2007 at 9:53:20 AM | Printing/Plotting Problems
rcobbjr
3.5 Stars: 3 Votes
I am using Revit 2008 and have created some construction documents for my project. When I print the drawings, some views have "information" such as lines missing. In some cases the lines are cut off. The data light on the plotter will come on for some sheets that I print. This happens when I plot straight from Revit and when I convert the sheet to PDF and plot the PDF.
Is this a "data crunching" problem? Can the problem be resolved by increasing the memory in the plotter?
If these are not the solutions to the problem, can someone provide me with a solution or at least a work around? Thanks.
Wed, Nov 14, 2007 at 10:44:58 AM | Printing/Plotting Problems
OktoberFire
OktoberFire Avatar
what plotter do you have?
with hp ones i know you can set the print job to computer memory, not plotter memory - this may cure your problems.
Wed, Nov 14, 2007 at 10:29:26 PM | Printing/Plotting Problems
rcobbjr
3.5 Stars: 3 Votes
I have access to HP DesignJet 430 and 450C. Do you change the settings on the computer or the plotter itself? Thanks for the tip.
Thu, Nov 15, 2007 at 3:36:02 AM | Printing/Plotting Problems
OktoberFire
OktoberFire Avatar
when you go to print, click the properties>advanced>Process Document ....put a tick in computer
plotting / printing
Wed, Feb 13, 2008 at 8:31:12 AM
Plotting
Tue, Jun 23, 2009 at 5:51:33 PM
Problems plotting
Mon, Nov 9, 2009 at 3:38:20 PM
Revit Print Problems - UPDATE
Fri, Sep 2, 2016 at 1:44:13 PM
Plotting Shadows
Tue, Feb 17, 2009 at 6:54:48 PM
Page generation time: 0.3318
