683 Users Online (65 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> Stone Veneer and Framing Plan
Tue, Nov 13, 2007 at 6:18:47 PM | Stone Veneer and Framing Plan
Bronsart
Hi everyone.  I'm still working on my first project... so this is probably growing pains.  I'm working on a residential plan with 2008.  I have stone veneer on some of my walls.  The problem is the framing plan does not show the stone veneer.  The load bearing walls are shaded... and the stone veneer is also shaded.  There is no distinction between the stud wall and the veneer on the framing plan.  It doesn't look right when my trusses stop 3" from the end of the wall.  Is there a way to fix this?  Thanks in advance for your help!
Wed, Nov 14, 2007 at 6:48:05 AM | Stone Veneer and Framing Plan
Dgodfrey
4 Stars: 4 Votes
Edit the wall properties so that the material settings for your stone veneer have a different "cut pattern" than your stud wall.
Wed, Nov 14, 2007 at 12:12:22 PM | Stone Veneer and Framing Plan
Bronsart
I'm sorry, I may not have explained my problem very well.  I have a cut pattern for the stone, but that pattern is not showing up on the framing plan.  I attached a pdf with the floor plan and framing plan in the area.  Also, the walls with the stone in the framing plan is shaded at a different density.  Do we have any flexibility how walls show up on framing plans or should I put this on the "wish list"?  Thanks for your help...
Parameter Formula Help Needed
Thu, Oct 15, 2009 at 10:57:55 AM
Stone Wall
Tue, Aug 20, 2013 at 3:55:33 PM
Stone Walls, Stone Veneer, etc
Fri, Oct 6, 2006 at 8:21:58 AM
Hatch / cut pattern problem after door insert in stacked wall
Mon, Aug 24, 2015 at 3:38:32 PM
Best approach for Stone Veneer component "hatch pattern"?
Mon, Sep 29, 2025 at 7:21:02 PM
Page generation time: 1.2526
