Forums >> Revit Building >> Technical Support >> New profiles for railings
Sun, Jan 4, 2004 at 3:34:01 PM | New profiles for railings
mac0
How would I go about adding a 4" circle profile to the railing when I am editing. This would be above the spindles along the length of the rails.?
Sun, Jan 4, 2004 at 3:43:15 PM | RE: New profiles for railings
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
would your circle be separate from your actual railing?
Hiroshi Jacobs
The Catholic University of America
Sun, Jan 4, 2004 at 3:58:16 PM | RE: New profiles for railings
mac0
The circle would be above the spindles inbetween two top rails. Cirlces are 1/2 x 1/2 flat bar rolled round and then welded inbetween the top rails at 5 1/2" centre's
Sun, Jan 4, 2004 at 4:46:01 PM | RE: New profiles for railings
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
have you tried editing the railing profile and adding in the circle?
Hiroshi Jacobs
Sun, Jan 4, 2004 at 4:48:07 PM | RE: New profiles for railings
mac0
Yes I have. But I dont have the image of the rings to put in. All I have is round or square spindles. Is there an upload of a ring or something I could modify to make the shape. I have limited experience. I have done the railing tutorial in 6.0.
Sun, Jan 4, 2004 at 5:37:57 PM | RE: New profiles for railings
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
open the profile family of the railing you are modifying. Save as with a different name and then draw your circle where you want it to be relative to the railing. Then import that family into your project. When you go to modify your railing, choose the new profile that you just uploaded
Hiroshi Jacobs
Sun, Jan 4, 2004 at 6:04:52 PM | RE: New profiles for railings
mac0
Is there a good tutorial to learn how to draw in familes. Not quite sure how to draw in that format. I did the one tutorial regarding massing in 6.0. Not quite sure how to make a circle after one tutorial
Sun, Jan 4, 2004 at 6:32:44 PM | RE: New profiles for railings
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
when you open your family, click "lines" and a number of drawing options will pop up directly above the drawing surface. you'll have the option to draw a line, box, cicle, arc, etc... Revit comes with a lot of good tutorials out of the box. Check the Help section in the program.
Hiroshi Jacobs
Sun, Jan 4, 2004 at 9:21:57 PM | RE: New profiles for railings
mac0
To difficult drawing the 3D ring at my skill level. Anybody have a similiar railing I could modify?
Sun, Mar 12, 2006 at 4:19:20 PM | RE: New profiles for railings
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
. You can get several great Video Tutorials on creating REVIT familes including profiles etc. at http://www.dgcad.com DGCAD
RAILINGS RAILINGS?????
Wed, Oct 1, 2008 at 3:48:49 PM
Frenc h railings
Wed, Feb 18, 2009 at 2:51:56 PM
11
Problems attaching railings to stairs
Mon, Dec 2, 2013 at 10:49:14 AM
stair railings-inserting glass
Mon, Dec 9, 2013 at 11:37:40 AM
Dimensioning railings
Fri, Jul 24, 2009 at 3:04:00 PM
Page generation time: 1.2901
