Forums >> Revit Systems >> Technical Support >> hide parameter
Fri, Oct 26, 2007 at 8:14:03 AM | hide parameter
Andrew126
Hi!
 How can I hide a parameter?
 Andrew
Fri, Oct 26, 2007 at 9:07:36 AM | hide parameter
KingRevit
4 Stars: 12 Votes
if its the label you want to hide the only way i know is to select the label- properties- change the colour to almost white and change the size of text arrows tick marks as small as possible.
if you don't want the parameter to show up in the element properties, thats harder, try nesting the family in another family.
if you let me know what paramiter and why you want to hide it there may be other ways.
Hide parameter
Wed, Feb 4, 2015 at 3:29:43 PM
Hide lines in tag with shared yes/no parameter from host
Sat, Oct 24, 2015 at 10:39:06 AM
Hide Instance Parameter ruled by formulas from the Property Palette
Thu, Nov 21, 2019 at 11:26:43 AM
Hide Isolate
Fri, May 2, 2014 at 2:34:08 PM
hide unreferenced tags
Mon, Oct 19, 2009 at 1:51:12 PM
Page generation time: 0.5783
