701 Users Online (33 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Structure >> Technical Support >> Revit and "connections"
Mon, Oct 8, 2007 at 5:26:35 PM | Revit and "connections"
chaggas
This topic has come up repeatedly in the office as of whether or not Revit can “do connections.” Since this is a new topic to me, I’ll do my best to explain what I mean. I’m referring to connections that are done in software programs such as ProSteel, where the software analyzes the structure and places the appropriate connections and bracings between columns and beams based on what type of beam/column they are and for how long they span. In addition to this, these connections will update automatically as the model changes, eg, move a grid line which will make a beam span a longer distance and the connection will update based on what is needed to connect that span of beam to the column or other beam.
Now I’ve seen a folder for connections in Revit, but after doing some of the tutorials I am left wondering if these connections in Revit are just detail items that have to be manually placed and updated or whether they have any ‘intelligence’ attached to them. Any comments on this topic that we help me better understand Revit and its capabilities would be infinitely helpful.
(Currently using Revit Structure and Architecture 200Shadey
Thank You
Thu, Oct 11, 2007 at 11:56:06 AM | Revit and "connections"
EDGinc
IF THERE IS SOME SORT OF "LIVE" OR "SMART" CONNECTION, I HAVE NOT SEEN IT YET.
I THINK YOU ARE CORRECT BY THINKING THE CONNECTIONS ARE SIMPLY DETAIL COMPONENTS.
(Sorry, cap locks)
Mon, Oct 15, 2007 at 12:51:12 PM | Revit and "connections"
chaggas
Thanks for the insight, but I'm a little curious as to how Revit does 'load calculations' without knowing the connections? Of course I haven't tried doing load calc. just yet...
Making a shortcut for Edit? [ 1 2 ]
Fri, Aug 24, 2007 at 10:26:05 AM
22
Revit 2018/2019 Steel Connections
Thu, May 10, 2018 at 8:05:17 AM
Free Video CADclip on Creating a REVIT Family Type Catalog File
Tue, Nov 17, 2009 at 7:23:56 PM
View Extents in Revit 2019
Thu, Apr 11, 2019 at 9:09:55 AM
Structural Connections / Mechanical Fixings
Tue, Nov 10, 2009 at 4:20:53 AM
Page generation time: 2.1951
