Forums >> Community >> Newbies >> Plethora of Questions about Schedules
Fri, Oct 5, 2007 at 7:44:49 PM | Plethora of Questions about Schedules
rcobbjr
3.5 Stars: 3 Votes
I am using a schedule to calculate the square footage area for each room. How do you insert a formula to calculate the total square footage of the structure?
In a Wall Schedule, I want the information about the height of each wall to be listed in the schedule. By default this is not a category in the schedule to be added as width and length are for example. How do I add a category in the schedule such as height and have the schedule to enter the height information for the wall?
I need to determine the total roof surface area that I have on a structure to determine the amount of shingles I am to use for an residential project. How do I create a schedule that will calculate the total square footage of roofing?
In a door schedule, how do I add a column that will inform a client of the space the door is swinging into? Or do I create the column in the schedule and enter the information manually?
multiple schedules
Tue, May 1, 2012 at 1:04:42 PM
Schedules for Information In Schedules HAHA
Mon, Feb 13, 2012 at 12:08:12 PM
Schedules on multiple sheets
Thu, Apr 27, 2006 at 11:01:59 PM
Complex Healthcare Projects - Can Revit do their equipment schedules too?
Thu, Nov 20, 2014 at 2:59:38 PM
Large number of schedules
Mon, Jun 20, 2011 at 12:56:18 PM
Page generation time: 0.6472
