55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Linked CAD files
Fri, Sep 28, 2007 at 9:48:20 PM | Linked CAD files
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Is there a way to turn off the layers of a linked drawing in Revit without having to open the ‘VV’ or the Visibility Graphic Overrides?  I dont' know which layers are which in my linked dwg and I have to guess to turn them off.  Is there a tool that is similar to the one in AutoCAD where I can just pick the ones I want off?
Denver, CO
Revit Architecture
Sun, Sep 30, 2007 at 8:23:22 AM | Linked CAD files
dianajohn
Lorne17
Select the CAD dwg from within Revit.
The options Delete Layers, Full Explode, Partial explode & Querry appear.
Select 'Query'.
Now select lines in the Cad dwg. A dialog box appears with the lines properties & the option to Delete or Hide in view.
Select Hide in View.
This is the same as turning off layers in 'VV' but you can pick the layers you won't to turn off.
Best of luck.
John A
Export from Revit To CAD with RELATIVE linked files
Wed, Nov 29, 2017 at 5:00:35 PM
Linked CAD files are not turning off
Tue, Nov 29, 2016 at 9:31:28 PM
14
linked cad files accross projects
Tue, Oct 30, 2007 at 2:30:07 PM
Constraining to linked CAD file
Thu, Apr 4, 2013 at 8:09:14 AM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 5:24:56 PM
Page generation time: 0.3501
