4 Users Online (2 Members):
Forums >> Revit Building >> Technical Support >> Elevation shows as section
Revit 9.1. I have my building model linked into the site model. The elevation mark was located inside the building and was showing as a section. I moved the elevation mark to the outside of the building however the elevation is still showing up as a section. How can I fix this? I tried to delete the mark and make a new elevation view buy then the linked model doesn't show up in that view. Need to print my sheet by tomorrow morning. Thanks.
Edit is still not working. Made a temporary fix by placing a section mark outside the building to get an elevation view but would still like to know the solution to the problem.
under VG check that your walls are turned on in that view also click on the tip of the elevation mark you should see an horizontal line that define the view extents make sure that line is out side the building
Edited on: Thu, Sep 13, 2007 at 3:56:47 PM
When I cut a section or elevation in revit, it shows what's behind the cut plane |
Fri, Dec 6, 2013 at 12:47:17 PM
Section cut material shows up grey instead of brown |
Mon, Apr 11, 2016 at 10:16:45 AM
topography in elevation shows up "blank" space. any work around? |
Wed, Apr 29, 2009 at 3:20:42 AM
12
Section and interior elevation missing from file once it is linked |
Tue, Jun 26, 2018 at 2:12:46 PM
Turn off section references that occur in the background of an elevation |
Wed, Jun 16, 2010 at 2:10:12 PM
