Forums >> Revit Building >> Technical Support >> How to move everything up 5000 feet!?!
Fri, Sep 7, 2007 at 5:26:29 PM | How to move everything up 5000 feet!?!
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello,
 Ok I actually figured out how to get an accurate topography map from the surveyors drawing.  Our location is in the mountains so the elevation is 5700'.  The dilema I have is I already built the house and it's allon 0'-0".  Now how do I move everything I've drawn up to the topography map?
Denver, CO
Revit Architecture
Fri, Sep 7, 2007 at 6:21:56 PM | How to move everything up 5000 feet!?!
Oak3s
In an elevation view change the level elevation to read accordingly.
ex:
level 1 0'-0" change to 5700'-0".
Level Display (only) to decimal feet
Sun, Aug 10, 2014 at 11:00:01 PM
12
How do you move an item along the z axis?
Sat, May 2, 2009 at 8:18:11 AM
Can't move component vertically
Fri, Apr 20, 2018 at 3:22:19 PM
Rendering toposurface under 0 feet
Thu, Apr 6, 2006 at 2:19:20 PM
Something wrong with toposurface cut/fill claculation
Sat, Feb 12, 2011 at 10:28:49 PM
Page generation time: 0.1197
