Forums >> Revit Building >> Technical Support >> Relief Area
Thu, Sep 6, 2007 at 12:13:48 PM | Relief Area
utearch1
I have an EIFS wall that I need to cut a large relief in. What is the best way to do it? The EIFS is 1 1/2" thick, and I want to create a shape that will cut-out 3/4" into the EIFS.
 Using 9.1
 Thanks
Thu, Sep 6, 2007 at 1:09:41 PM | Relief Area
broncos4life
3.5 Stars: 11 Votes
Vertical or Horizontal?  If horizontal you can put a reveal in the properties of the wall->edit new-> then make sure your preview is in section and with that you can cut a horizontal reveal into the wall.  (You can also make bump outs in the wall this way as well.)  If they are Vertical the only way I know how to do that is by making a wall hosted generic model that cuts the wall.
Thu, Sep 6, 2007 at 1:24:50 PM | Relief Area
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You can also use a hosted reveal. They can be changed from horizontal to vertical.
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:26 PM
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:03 AM
Unusuall wall relief and window brick arch
Sun, Dec 5, 2010 at 4:00:08 PM
Area Plans
Wed, Nov 1, 2006 at 10:03:12 AM
Revit 2011 products crash when attempting to replace material render appearance
Tue, Jul 5, 2011 at 10:44:16 AM
Page generation time: 0.1103
