7 Users Online (5 Members):
Forums >> Revit Building >> Technical Support >> removing anchor in family - revit 9.1
1 Posts No Rating |
i'm pretty new to editing families and revit in general. i'm trying to edit a double storefront door family so that i have a single storefront door. i deleted everything but it has some constrains on it so that it still wants a double door opening. if i put the door in a 3'-0 opening it makes the door 1 -6 because it thinks the other door is there - basically leaves an opening in that area. it has eq dimensions that i can't delete and anchors on the reference planes. i can't delete the reference planes on the "empty" side. anyone know how i can just get the constraint or anchor to be deleted so i can just have one door. thanks
Carol Reeves, AIA SYNRGY design RESIDENTIAL * COMMERCIAL * CONSULTING |
Storefront / curtain wall doors are different than "normal" doors. They are not typed to size. Instead, they size themselves according to the panel you put them in. If you are going to start with the double door, just remove one side then make the remaing door the full width of what you started with. (redo the extrusions and symbollic linework) The eq constraints and reference planes will define your door with the center in the center of your door.
How do I set an equality anchor? |
Thu, Oct 26, 2006 at 7:30:59 PM
How to make anchor bolts group?? |
Sun, Jan 31, 2016 at 9:22:24 PM
System Family Question |
Thu, Nov 11, 2010 at 11:42:23 AM
Columns & Footings...aqttachment |
Fri, Mar 5, 2010 at 8:16:49 AM
Expansion Anchor Table |
Mon, Jan 16, 2017 at 12:50:20 PM
