Forums >> Revit Building >> Technical Support >> Colour/Finish Parameters on Components
Wed, Aug 8, 2007 at 11:36:17 PM | Colour/Finish Parameters on Components
NickNZ
I am currently building up a set of components of a local aluminium manufactures residential doors and windows. The problem I am having is creating a parameter, which will appear in the schedule, on which the user can chose from a drop down box of options of the powdercoat finishes avaliable for that item. How would I create this parameter? Also, is it possible to link the parameter to the frame/mullion finish in the materials box and thus have it automatically change when either box is altered? This is hard to explain in text, sorry.
Cheers. Nick
P.S. I am using Revit 9.
Changing the Colour of a Material
Fri, Nov 16, 2012 at 3:21:06 PM
No colour for rendered skp files
Thu, May 7, 2009 at 10:24:37 AM
help with family parameters to show colours in elevation views.
Tue, Nov 30, 2010 at 7:14:20 AM
Room - changing the title to room finish
Fri, Nov 1, 2013 at 7:29:51 AM
How do you tell what finish has been applied with Paint?
Sat, Jan 26, 2013 at 5:14:41 AM
Page generation time: 0.2560
