Forums >> Revit Building >> Technical Support >> BUG - Visibility Graphics not working correctly
Wed, Aug 8, 2007 at 12:22:21 PM | BUG - Visibility Graphics not working correctly
Version 9.1
I just finished a family with a new sub category line type. (symbolic)  I have placed the family in the model and changed all existing instances to match the new family.  I do not want this line to show in every view so I changed my view templates to turn this line off in those views.
NOW FOR THE PROBLEM  I applied the correct view templates.  However, when I open the views, the linework is still there.  I check the VG for the view and it correctly shows that the lines should be off.  No matter how many times I close the view and re-open it or check the VG, the linework is still there..... BUT  if I change the VG for anything.... the linework disappears.
This is not a nice problem to have.  I can't trust REVIT to correctly show a view even though it is set correctly.
Seems that REVIT has a problem here.  I've just installed REVIT Architecture and I will see if it has the same problem
Visibility Graphics for Linked models not working (2009)
Fri, Apr 24, 2009 at 11:02:36 AM
Visibility/Graphics and Detail Components
Wed, Feb 23, 2011 at 2:53:36 PM
visibility graphics problems-please help!
Sat, May 28, 2011 at 4:33:53 PM
Curtain Panel Rep. in Plan not displaying correctly in Project
Fri, Feb 26, 2016 at 1:29:14 PM
Visibility Graphics and printing
Fri, Nov 12, 2010 at 3:14:24 PM
Page generation time: 1.3998
