10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> revoled families
i have made 3 round columns 8,10,12 inch. each are a seperate family that i can adjust the hieght of with parameters, by making a profile of the column then revoling it about the axis. my question is could i have made 1 family then made the 8,10,12 inch column from that rather than 3 seperate families. i didn't know if a revolution could be changed in the family itself. can set parameters for the base of the column,which is square in shape but not the width of the revolution. am i correct in how i have created the families.
admin
you can set a parameter for any dimension in your family, whether it be the width of the base or the radius of your round column. If the profiles of your columns are the same, you probably could have created them in just one family.
Hiroshi Jacobs
The Catholic University of America |
10 New REVIT 8.1 'Families' Video Tutorials released |
Tue, Oct 2, 2007 at 12:39:43 PM
Edit Default Families |
Sun, Jan 24, 2010 at 8:23:42 AM
Revit Families |
Fri, May 24, 2013 at 4:23:33 PM
12
Replacing Multiple families in a Project. |
Mon, Oct 15, 2018 at 10:34:29 AM
Rendering Families in Revit 2010 |
Mon, Jul 19, 2010 at 5:39:45 AM
