5 Users Online (3 Members):
Forums >> General Discussion >> Wishlist >> break gridlines
3 Posts No Rating |
It would be helpful to have the ability to break a gridline in the center in certain views, similar to section cuts, in order to unclutter an elevation drawing but still be able to reference levels.
You can toggle the 3D/2D extents of gridlines. Select a gridline and you will see a "3D" tag next to the control. If you click this tag it will change to "2D" and allow you to move that endpoint independantly for that view only. As breaking a gridline between the head and the endpoint, I don't think that is possible at this time. HTH
3 Posts No Rating |
great, that might be just what we need to do for this project but I do think it would still be helpful if the break function could be incorporated into the gridlines in the program. Thanks a lot though!
I agree with Macy, it would be good to be able to break gridlines to clean up the floor plans. I have a situation at this moment where I could use that feature. Using version 9.1.
17 Posts No Rating |
I echo the desire to make gridlines able to break in the center - I've got an overly cluttered floor plan, so it looks like I'll have to revert to ACAD for this one.
dimensioning gridlines |
Sat, Nov 4, 2006 at 10:27:59 AM
Gridlines |
Fri, Aug 8, 2008 at 3:24:08 PM
Building Gridlines vs Underground Gridlines |
Thu, Mar 17, 2011 at 1:49:59 PM
re-numbering gridlines |
Wed, Mar 26, 2008 at 3:08:06 PM
Gridlines in front of Model / Linework |
Tue, Jul 13, 2010 at 12:45:01 PM
