Forums >> Revit Building >> Technical Support >> Revit Glossary
Thu, Jul 26, 2007 at 10:40:17 PM | Revit Glossary
vector23
vector23 Avatar
2 Stars: 16 Votes
does anyone know of anything like a Revit glossary?
FOR EXAMPLE: suppose you are reading along and you read something like:
"Elements within the boundaries of the primary range that are not cut are drawn in a projection line style."
so you say okay fine "projection line style" i'll just look that up..
but when you search in the help it always takes you right back to where you got it from..
i'm always needing a definition of Revit terms..
is there a Revit dictionary or glossary or some way to look up words and terms used
with Revit? just googling the words and terms don't usually yeild much..
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
We are looking for Revit Users [ 1 2 ]
Thu, Mar 31, 2011 at 5:15:24 PM
17
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:52 PM
16
Page generation time: 1.2572
