34 Users Online (32 Members):
Forums >> Revit Building >> Technical Support >> Smart Family and Symbolic Lines
2 Posts No Rating |
I realize that this should most likely be posted under the REVIT Systems forum since I am using MEP2008, but there is not much activity over there. I am trying to make a "smart" diffuser family and I have been sucessful in makeing a 3D model of the diffuser that will change in size when I change a "length" and "width" dimension. The problem I am having is that when I try to apply symbolic lines to the diffuser (Basically an X over a rectangle) I can't get the symbolic lines to change in size proportional to the "length" and "width" dimensions. Any suggestions would be appreciated
Henry Adams, LLC Consulting Engineers 410-296-6500 |
You have to align then lock the ends of the symbolic lines to the width ref & then the length ref. draw them to the intersection then align them by tabbing through to pick the line end. Hope this helps.
Macca Sunshine Coast QLD Australia |
2 Posts No Rating |
Thanks for your response, I got it to work. I think my issue was I was not using reference lines to constrain my parametric variables to.
Symbolic Lines and Model Lines |
Wed, Mar 22, 2006 at 12:52:17 PM
Symbolic Lines Variation in Family |
Thu, Feb 15, 2007 at 1:33:21 PM
Symbolic lines in elevation |
Thu, Jan 10, 2008 at 7:12:53 PM
symbolic lines |
Thu, Jul 13, 2006 at 8:15:41 PM
Windows above the Cutplane and Symbolic Lines (Revit2010) |
Wed, Jul 14, 2010 at 7:35:42 AM
