59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> Origin 0,0,0
135 Posts No Rating |
Hi all, when i go to ->shared coordinates -> specify coordinates by a point -> and select a point for 0,0,0, why is this point not the 0,0,0 point when I export this model to 3dsmax? E
Not sure. What I did long ago was make a simple autocad file with an "x" at 0,0,0 and imported it into Revit so I knew exactly where it was. I've read stories where someone has been off by like 17 miles! This can cause big problems being off this much.
When you export, click options and you;ll see a pull down that defaults to project internal. pull that down and chose shared. In revit the project internal 0,0,0 is NOT able to be moved. But you can specify a point as you have that you want revit to export to as 0,0,0,
Origin to Origin |
Tue, Jul 5, 2011 at 8:18:16 AM
Point Clouds Origin to Origin |
Tue, Nov 8, 2011 at 11:23:30 AM
Acad Import - Origin to Origin |
Wed, Aug 1, 2007 at 5:57:25 PM
linking models via origin to origin problem |
Wed, Sep 30, 2015 at 10:20:09 AM
Mis-aligned Origin to Origin in linked Revit Architect into Revit Structures |
Fri, Nov 18, 2011 at 7:26:33 AM
Members: | 1991745 | Objects: | 22879 | Forum Posts: | 152183 | Job Listings: | 3 |
